SailNet Community - View Single Post - Heaving-To versus Bare Poles
post #9 of Old 07-29-2008
sailingdog
It is, but it depends on the conditions, the wind direction, where the nearest land is, and what boat you're on. IF you're on an old full-keeler, like a Southern Cross 28, with plenty of room to leeward, then it is a great tactic to use. If you're in a very modern, ULD racing boat, with a very high aspect bulb keel, it might not work out so well.
If you have a lee shore fairly closeby, it might not be a wise tactic, as it might still allow your boat to blow down onto the lee shore—but it depends again on the boat, the wind, the position of the land, etc.
A boat that forereaches when hove-to, might make enough progress to windward that a lee shore isn't a big deal.
Originally Posted by kwaltersmi View Post
So it sounds like most of you feel that heaving-to isn't a heavy weather/storm tactic.
I've practiced heaving-to many times in light to moderate air, but never in heavy weather. I know it's a good skill for taking a break from sailing or an onboard emergency that requires your attention away from the cockpit for a bit, but there's something in my memory that recalls reading about heaving-to as a method for riding out a storm.
sailingdog is offline
