AFAIK, the USCG doesn't approve any sea anchors or drogues whatsoever. The loads a sea anchor will put on a boat are far greater than those generated by a JSD. Also, experiential data has shown that the risk of being pooped while using a JSD is minimal.
I hope you reinforce what ever hardpoints you plan on using for your parachute anchor.
BTW, from another post I wrote.
Much of Jordan's work was done because of the Fastnet disaster. That was what prompted Jordan to design the series drogue in the first place. He also worked very closely with the USCG in the development and testing of the JSD. While the USCG doesn't approve the JSD, it certainly seems, from the document on Jordan's site, to advocate the use of them.
If you read the USCG report, the report's abstract says:
Model and full-scale tests were conducted to investigate the use of drogues to prevent breaking wave capsizing of sailing yachts. A mathematical model was developed which simulates the motion of a boat and drogue in regular waves and in a breaking wave strike. A series drogue is recommended for optimum performance based on the results of this study. Design information for both series and conventional drogues is presented.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
