SailNet Community - View Single Post - varnish alternatives
post #6 of Old 07-31-2008
sailingdog
The other point is that a mast is generally varnished around its entirety, where a toe rail is generally only varnished on the exterior, not the underside. So there are edges that water can easily get under on a toe rail, which may not be the case on a mast or boom. Also, water tends to sit along the base of a toe rail, right along the most vulnerable area, where the varnish's coverage ends... this is not the case with a mast.
sailingdog is offline
