SailNet Community - View Single Post - old glass hull v. new glass hull
post #5 of Old 10-30-2003
Jeff_H
Moderator
Jeff_H's Avatar
With all due respect, I disagree with the statement "cored hulls ...are weak and do not resist impact as well as a heavy lay up." In a properly designed and constructed cored hull that simply is not the case.
In actual testing performed by the US Naval Academy (from a paper presented at the 2002 SNAME Chesapeake Bay Sailing Yacht Symposium), non-oriented fiber reinforcing fabrics were found to be the primary mode of failure in point impact situations. This paper outlined that Naval Academy cutters, which are used in training exercises, are subjected to frequent collisions, but the Academy cannot afford to take them out of usage for long repair periods. As a result, impact resistance was very critical. In order to test the impact resistance a large pendulum with a massive weight was constructed. On the leading edge of the pendulum was a steel replica of the bow and stem fitting of a Naval Academy cutter. Test panels were constructed that matched both known (prior cutter lay-up schedule and J-24 topsides) and conjectural hull panels. The panels were aged and then tested warm (some resins lose strength when warm). The tests consisted of retracting the pendulum with a forklift and then releasing the restraint cable. The results were very dramatic.
To begin with. Solid hulls did far worse than cored hulls. In examining the panels after the collisions, the failures almost always occurred in the non-direction material being used and not in the core materials. The test sample that faired best used an oriented glass laminate, NO non-oriented materials, vinylester resin, and a high-density foam core. The pendulum never entered the outer laminate and microscopic analysis further destructive testing showed that core was still fully adhered to the skin and that the deformation was within the elastic (memory) properties of the core.
Jeff_H is offline
