SailNet Community - View Single Post - fresh water system stopped working after fill-up
post #3 of Old 08-01-2008
tommyt
Disconnect the water line just prior to the pump and see if gravity pushes water through it. Most tanks, when full, are above the pump so gravity allows the flow. If there is water there, then you have a pump issue. If not, probably a valve shut off somewhere. Usually water problems are more a matter of tracing the problem rather than a major issue. Just like electricity, it flows!
tommyt is offline
