SailNet Community - View Single Post - fresh water system stopped working after fill-up
Old 08-01-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
If the boat is brand new, there is a fair chance you have an obstruction from construction debris that was not adequately cleaned from the tanks. More than likely it is clogging the inlet at the pump. Alternatively, the hose clamps may need to be snugged so the pump won't draw air.
Another possibility is that the air leak or blockage is at the manifold, which might explain why switching tanks had no effect and your "back-up" pump also did not work. It's difficult to say for sure without seeing a water system schematic. Is your back-up pump a foot-pump?
