SailNet Community - View Single Post - fresh water system stopped working after fill-up
post #7 of Old 08-01-2008
allegedly
Send a message via Skype™ to allegedly
Bleed the system. Turn on the pump. Open all the faucets including fresh water lines into the toilet, if you have them. Close them starting at the sink or head furthest from pump. Check tank for leaks, Bene's use plastic tanks that can split if too much pressure is used.
allegedly is offline
