SailNet Community - View Single Post - Changing A Raw Water Impeller (How To)
post #35 of Old 08-01-2008
captbillc
ancient mariner
captbillc's Avatar
ancient mariner
haleki 36 that is a great w/p impeller photo ! i thought every one can use an aid to install the impeller. use a hose clamp and curve all the blades in the same direction as you tighten the clamp till they are small enough to enter the houslng. just be sure they are bent in the right direction when you push the impeller in. this makes the job easy. i am a retired diesel mechanic and use this method
captbillc is offline
