SailNet Community - View Single Post - fresh water system stopped working after fill-up
post #15 of Old 08-01-2008
T37Chef
T37Chef's Avatar
Originally Posted by Bene505 View Post
Now it doesn't work, only sputters a small bit of water out of the faucets. Any ideas?
How long did it sputter?
I ask because if I have run the tanks down, the water heater as well, it takes some time for the pump to pump water into the water heater and build pressure in the system, and will get the sputtering as you describe until the system is primed.
Maybe all you need to do it give the pump some time???
Shawn
T37Chef is offline
