SailNet Community - View Single Post - Survey Says!!
Thread: Survey Says!!
post #1 of Old 08-04-2008 Thread Starter
Teirst
Post Survey Says!!
Was wondering if I could get some interpretation. I got a survey for a boat that I have been interested in but have been a little unsure as to what all the numbers and things meant. I believe that the boat would be a good purchase but then who shoots down a second opinion. Let me know what types of other information you would like but here are what I think are the big ones. let me know what you think about it
1969 Columbia 36 sloop
Ge aquant moisture meter scale of 1-999
Hull below water line (less than 247)
Hull above water line (88-116)
Cockpit (27-109)
Hull surface: observed minor compression dimples, abrasions, and gel-coat voids of no structural consequence (cosmetic only) both sides amidships well above waterline
Hull to deck join: shoe box style, aft sections of the coaming have sustained damage on starboard side and appeared to have been partially repaired. I recommend thorough repair.
Engine: atomic 4. engine was bonded but has 608k ohms resistance to shore power ground receptacle and fuel tank. Resistance from fuel tank to engine was 5.5k ohms. And fuel fill was 750k ohms to engine block as well
thanks for all your help!
Teirst is offline
