SailNet Community - View Single Post - foggy windows... advice needed.
post #6 of Old 08-04-2008
Bermuda30
On Blocks
Bermuda30's Avatar
I'll second the Novus products. If you can't get your hands on those, auto parts stores stock polishes to restore yellowed/hazy headlights that work quite well.
AS for replacing, the frames on the grampian are removable, and new plexi can be inserted. Personally, I will be replacing mine with 3/8" surface mounted ports, a little thicker than the flimsy stock ones.
http://www.sailnet.com/forums/gear-m...ted-ports.html
The stock grey gaskets can be found here:
Holland Marine Products
1971 Grampian 26
Bermuda30 is offline
