SailNet Community - View Single Post - Glue/Weld Plastic?
post #2 of Old 08-06-2008
RAGTIMEDON
RAGTIMEDON's Avatar
If this is really a nipple, have you considered a brass nipple from a plumbing supply store? if it is part of a molded faucet, is there enough material in the body to cut off the nipple, drill it out, and epoxy in a barbed fitting to connect the supply line? that would be stronger than gluing the nipple, because of the solid part of the faucet around the glue joint.
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
RAGTIMEDON is offline
