Raymarine E120 Problems
I recently upgraded my display to an E120 Display and am curious if
anyone else has experienced the following problem.
While motoring at night I dim the brightness setting. I don't use the
night setting as I feel it is too dim. What happens is every 5 - 10
minutes the display will either go dark then momentarily go to full
brightness then back to my dimness setting or just go full brightness
momentarily then back to my dimness setting.
Raymarine's tech services says they haven't heard of this problem
before, so it's must be low voltage. If is not that then I should
send in my display so they can check it out. The unit is new and
according to Raymarine has any improvements already incorporated into it.
The below boats are experiencing the same problem, they are:
Tom Jeremiason, Camelot, C470 - 145
Dick Dresler, Last Resort, C470 - 140
Bill Martinelli, Voyager, C470 - 11
Roger Frizzelle 470 #147 same problem E 120
Roger Goddsell 42 same problem E 120
Jesse Hibdon 440 # 25 same problem E120
Joe Rocchio, Onward, C470 126
Please let me know if you are having the same problem.
Thanks,
Bill Martinelli
Voyager, #11
