SailNet Community - View Single Post - Deck Refinish
Thread: Deck Refinish
post #10 of Old 08-08-2008
sailingdog
Are you serious??? the problem with 5200 is that it pretty much sticks to everything, far too well, to be considered less than permanent. You might want to read a bit about the product, PDF HERE. 3M 5200 is often used for hull-deck joins as well as keel-hull joins... not ideal IMHO for either use, since it is far too aggressive an adhesive... but still.
Originally Posted by funsailthekeys View Post
3M 5200 only sticks to wood and fiberglass 4000 polyester adhesive sealant sticks to thru hulls,mechanically fastened joints on wood or fiberglass, metal and most plastics. The list is much longer but you get the idea. The 4000 is pretty much an all around sealant.
sailingdog is offline
