SailNet Community - View Single Post - Hot engine won't start
Old 08-11-2008
erps's Avatar
erps erps is offline
the pointy end is the bow
The click you heard was the starter solenoid switch closing. Two things are possible. Either the engine was so hot that it was partially seized, and the starter couldn't budge it or the hot starter had high resistance and couldn't pass enough current through the contacts to spin the motor. I think the second was more likely.
Were there any other problems with the cooling system that may have caused the over heat problem? An overheat due to low oil is quite a bit more serious than a overheat due to low water.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
