Old 08-11-2008
jrd22's Avatar
jrd22 jrd22 is offline
Courtney the Dancer
jrd22 is on a distinguished road
I would agree with the posts above that this is a water/coolant issue rather than oil. What was the water temp (if there is a guage) when the alarm went off? I would determine if you are getting enough raw water flow through the exhaust and also check your coolant level. I always change thermostats if an engine overheats, and changing the impeller on the raw water pump, or at least checking it would be a good idea.
John
John Davidson SV Laurie Anne
1988 Brewer 40 Pilothouse
