Right of Way at Mark
If I recall it right, if you have already started tacking, and before the other boat was 2 boat lengths form the mark, he has to let you finish the tack, the inside overlap will be desided after you finish the tack. That said, if he is inside 2 boat lengths PRIOR to you starting the tack, than you need to fall offand should not try to round the mark nor initiate a tack.
