SailNet Community - View Single Post - Hot engine won't start
Old 08-12-2008
Boasun's Avatar
Boasun Boasun is offline
Boasun will become famous soon enough Boasun will become famous soon enough
Gauge your engine!! You'll want; Oil Temp, Coolant Temp, Engine Oil Pressure, and transmission temp & pressure (if possible). All of this along with the Tachometer. Then add in the if you can the low level oil and coolant alarms along with the other temp alarms.
With the gauges you can log your engine's operation temp & Oil pressures, while in use. Then any changes will stand out like a sore thumb.
An Hour meter also for those pesky oil changes at regular intervals.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
