SailNet Community - View Single Post - Companionway Hatch
post #2 of Old 08-13-2008
Drewboy
Darrell, here's what I did on our 83 Newport II. See attached picture (if my attachment worked!) Removed all the old wood insert. Remaining base and frame is fiberglass. Set in a new base with plastic wood to 1/16" below top surface. Cut and laid in a new wood laminate layer using waterproof Gorilla glue. Filled in remaining gap with fiberglass epoxy. Painted outside frame with marine enamel. Then I put 5-6 coats of marine varnish on. Loved the result.
Andy
Drewboy is offline
