SailNet Community - View Single Post - RI South early October
post #3 of Old 08-14-2008
camaraderie
moderate?
camaraderie's Avatar
There is an "ICW heading south thread" that you can use to post your intentions and timing and hook up with others. Leaving in early Oct. from RI will put you behind most southbound boats. Suggest you try to be in the Chesapeake by early October if you can adjust your timing and hook up with others at the boat show for the passage south from there. There is also a southbound cruisers rally in New Bern NC shortly after the boat show. Here's the thread:
http://www.sailnet.com/forums/cruisi...outh-list.html
camaraderie is offline
