A properly tied bowline isn't going to magically untie itself, and un-doing the bowline is going to generally damage the line far less than trying to get a buntline hitch out. For a bosun's chair or climbing harness attachment, you want a secure knot that is easy to remove when you're done with using the chair/harness. A buntline hitch doesn't qualify for that use IMHO.
Buntline hitches are great for places where the knot is basically permanent, like attaching a main sail halyard to a headboard shackle, but not so good if you want to be able to use the line for something other than the buntline hitch.
Originally Posted by SEMIJim
That's rather the point, in this application, SD
Jim
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
