SailNet Community - View Single Post - Jacklines
Thread: Jacklines
post #10 of Old 08-17-2008
SailorMitch
Senior Moment
SailorMitch's Avatar
The ORC recommendation for breaking strength is 4,500 lbs. I just bought jacklines for my boat from JSI. The highest breaking strength I could find was about the 5,700 lbs quoted above.
here's the ORC reference.
4.04.1The following shall be provided:
a)Jackstays:
iattached to through-bolted or welded deck plates or other suitable and strong anchorage fitted on deck, port and starboard of the yacht's centre line to provide secure attachments for safety harness:-
MoMu0,1,2,3
iicomprising stainless steel 1 x 19 wire of minimum diameter 5 mm (3/16 in), or webbing of equivalent strength;
MoMu0,1,2,3
iiiwhich, when made from stainless steel wire shall be uncoated and used without any sleeving;
MoMu0,1,2,3
iv20kN (2,040 kgf or 4,500 lbf) min breaking strain webbing is recommended;
MoMu0,1,2,3
vat least two of which should be fitted on the underside of a multihull in case of inversion.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
