SailNet Community - View Single Post - Considering a Pearson 323
post #6 of Old 04-14-2001
michaeledelson
UPDATE: for anyone reviewing this thread.
I don''t know what boat you were on that was deck stepped and fastened with screws, but it was not the 323.
I just took off some of the wood panels and exposed the hull-to-deck joint.
The deck of the 323 is bolted to the hull with beefy bolts. There are also self-tapping screws, but those hold the rub-rail in place. The bolts are about 6 inches apart and appear quite sturdy, with no sign of leakage or corrosion.
If you''re considering a 323 and you want a boat built like a tank, you found it.
michaeledelson is offline
