SailNet Community - View Single Post - Lewmare Super Lock or Spinlock XAS Rope Clutch?
post #1 of Old 08-19-2008 Thread Starter
zz4gta
I don't discuss my member
zz4gta's Avatar
I want to get a double rope clutch set up for my Main and Jib halyard. I've narrowed it down to 3 possibilities.
I've heard Lewmar doesn't wear out lines as fast.
Spinlock grips harder
and Garhauer doesn't make any for 1/4" line, but I've emailed to see if they'd start carrying them.
The spinlocks (IMHO) look better than lewmar, but I've personally seen 2 of them break on 2 separate boats. They continue to hold but the handles break off either when they're left open and someone steps on them, or if there's a bad lead coming out of the clutch they won't close all the way, if you force them, you can break the handle off by hand.
I believe the handles breaking on the spinlocks are due to sun exposure and the plastic getting brittle. Does lewmare have the same issues? If Garhauer would make clutches for 1/4" lines, this wouldn't be an issue, as they use aluminum handles.
Merit 25 # 764 "Audrey"
zz4gta is offline
