  #61 (permalink)
Old 08-20-2008
sailingdog sailingdog is offline
Don't store the propane canisters below. They're prone to leaking, especially after being used once...
The best storage system for them is to make a "propane locker" for them out of Schedule 80 PVC pipe. The locker is basically a section of tube with end cap welded on the bottom, that has had a large 1/2" hole drilled in it. The tube is then fastened to a stanchion or the lifelines and the propane tanks are dropped into it. Another end cap is put over the top and fastened either by a hole drilled with a 1/4" fast pin or a piece of bungee cord.
Originally Posted by Joesaila View Post
Just finished a second 150 mile sail around the outer cape to Nantucket, M.V. and the canal. Each trip lasted a week and there were 4 adults on board. The non pressurised [2 burner Origo] lasted on a single fill up at the start and there were no problems. [I would never try to fill it while sailing] Its not difficult at all to see the blue flame and the heat was very sufficient. I am looking for a way to make bread. [we don't have an oven, but I'm certain it can be done] We do have a propane grill for the rail and I would like to find out about safely stowing those small tanks below. Is there a locking box or system anyone is aware of?
