SailNet Community - View Single Post - Pickling A Gas Tank
Old 08-20-2008
sailingdog sailingdog is offline
Why don't you use fogging oil, since it is basically forumlated to stick to metal surfaces and protect them from corrosion.
FYI, having your gas tank setup so that it drains overboard in the case of a gas leak or spill is probably illegal. The MARPOL convention states that overboard discharge of petroleum based products is illegal and the USCG and EPA can hit you for big fines if it happens. A placard for the law, as required on boats over 26' LOA, like yours, says:
Originally Posted by CellNav View Post
The gas tank in my Atomic 4 powered C-27 was giving me problems with sediment. I've since installed a 5 gal plastic tank in the aft lazerette for safety. If the tank leaks, the gas drains overboard instead of pouring into the bilge. I've drained and cleaned the internal steel tank. What can I use to pickle the tank and prevent corrosion? Deisel attracts water and gas defeats the purpose. Any thoughts?
