SailNet Community - View Single Post - Sweet Heat
Thread: Sweet Heat
post #6 of Old 08-20-2008
tomaz_423
tomaz_423's Avatar
Washing your hands helps only partially.
The hot substance does not dissolve in water. It dissolves much better in oil.
So, to remove it this helps:
1. Wash your hands normally (to remove some)
2) Oil your hands (either with edible oil or with a hand cream and rub well
3) Wash again to remove the rest of hot stuff and oil from your hands.
4) repeat if needed.
If you use liquid soup with added oils it can be of some benefit.
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
