Old 11-25-2003
geohan geohan is offline
geohan is on a distinguished road
How to take off prop????
To remove the propellor only, dive yourself or hire a diver to do the job. Or, put the boat up on a tidal grid if the underbody can take it and the tidal range is sufficient. Another option is if you can find a sandbar with a fairly steep slope (look around at low tide) and adequate tidal range, beach the boat. Finaly, you might be able to careen the boat, down by the bow, enough to reach the prop from the surface either in floatation gear or a dingy. Interestingly, an engineering friend made his 40-foot sloop the center of a timber sandwich and let it dry out on a flat beach. The 8x10 timber under the keel was an old railroad switch tie which was connected to the upper smaller timber with chains and turnbuckles. the upper timber spanned the boat and was supported at the gunnels near the shrouds. Then of course, there is the method in England where struts are rigged at the shrouds to enable the boats to dry out unattended. While a haulout at the boatyard may not be cheap it will get the job done and that''s about all I can think of on this subject.
Regards, George.
