Keel bolt issue
IMO you should remove the nuts off these bolts, drop the keel, remove the bolts and replace them. Keel bolts shold be attached with nuts thru the boat''s keel and the nuts should be accessible so that they can be tightened if needed. Use tobin bronze for the new keel bolts and you will not have this problem again.
