SailNet Community - View Single Post - Battery Selector: Run with ALL or 1 or 2??
post #3 of Old 08-30-2008
hellosailor
A 30-year old battery switch may not be making proper contact anymore, the contacts do wear and sometimes shift. I'd be tempted to replace it, or to install a battery combiner switch (West/Yadina or Hellroaring) which starts you on the starting battery, then combines both to charge/run once the alternator has come up to full voltage in a minute or two. When you shut the engine, it disconnects them again, so your starting battery is just isolated for starting use while you are on the house bank.
hellosailor is offline
