SailNet Community - View Single Post - Product Reviews
Thread: Product Reviews
post #65 of Old 09-03-2008
sailingdog
Just make sure the shackle is in the correct orientation as described in the addendum to the manual... since the shackle pin can back out if it is in the wrong way...and that would be bad.
Originally Posted by artbyjody View Post
I had had a halyard jammed up the mast due to a "racer's" excitement, and then that asym mishap with stuck halyard mid way. West marine recalled their bosun chairs but discovered they actually sold the ATN Topclimber - and since it was race day - purchased it.
While I only went halfway up, I did find with a little bit of practice it worked fairly efficiently. It does though put the load of climbing up on the climber (then again I am scared of heights and was kinda shocked how fast I went up before I looked down), and I would still recommend having someone else manning a halyard attached to the unit for safety. But, it is nice to know it is a unit that works as advertised and in a pinch if I had to - I have the ability to get myself up the mast. It is also fairly comfortable.
For those that do rock climbing - in principle it works very much like some of the systems you may use. At any rate I would recommend the product albeit its a pricey solution.
sailingdog is offline
