SailNet Community - View Single Post - Cotter Pin
Thread: Cotter Pin
post #7 of Old 09-03-2008
sailingdog
Cam—
Cotter rings, IMHO, are far more likely to work loose, and I don't use them in the upper rigging, where inspection is more of an issue. I also don't use them in certain locations on my boat, like near the ama folding mechanism, since they'd take up more room and would be more likely to get damaged or jam the folding mechanism.
IMHO, they're best used where they can be, and should be, inspected regularly. Their greatest advantage is that they are relatively easy to remove and re-use, so I use them on things like the gooseneck pin of my boom, where it is easily inspected, and easily reused—since I generally remove the boom when I lower the mast.
sailingdog is offline
