SailNet Community - View Single Post - Transducer suspended in vegie oil. square to the bottom
post #7 of Old 12-20-2003 Thread Starter
obiec
Thank you for all the replies, I have mounted several transducer in the past to the hull of my boats, But there are no flat spots on this boat. what I was realy asking was if Epoxy reson would brack down PVC or Poly carbon. For the person wonting to use the transom mount transducer go for it it will work. I have nerver like using silacone for the job but have always used a thikent Epoxy. On one boat I even built a dam about 3/8 high so I could ajust slightly for the hull shape. it worked will. I like the 5200 Idea and think I will use some 6" pvc pipe with 5200 to hold it. Will let you know how it turns out.
obiec is offline
