SailNet Community - View Single Post - Battery Setup: Blue Sea ACR?
post #8 of Old 09-08-2008
jbondy
Senior Mumble
jbondy's Avatar
Originally Posted by artbyjody View Post
Jim,
Yes, you would be correct that there is no manual switch for the starting battery - its because it doesn't need it, as you wire the engine starting wire to the post that is for the starting battery.
Is this the correct way to wire this set up? The BlueSeas switch opens and closes two independent circuits, with a third position for combining them. I have this set up and wired the start switch to one the switched circuits so I could cut it off if there was short anywhere in the starting system.
jbondy is offline
