SailNet Community - View Single Post - Battery Setup: Blue Sea ACR?
post #9 of Old 09-08-2008
artbyjody
artbyjody's Avatar
Originally Posted by jbondy View Post
Is this the correct way to wire this set up? The BlueSeas switch opens and closes two independent circuits, with a third position for combining them. I have this set up and wired the start switch to one the switched circuits so I could cut it off if there was short anywhere in the starting system.
Well there are four posts on that selector combiner switch. That is probably a decent idea there Jbondy - but one that is unneccesary I think as a short anywhere in your starting system will trip the inline fuses (assuming you have those installed per Blue Seas documentation).
Commenting on some other posts here:
What people fail to realize that it automatically handles the starting battery when starting the engine with no need for combining. Even if the starter battery goes low it will auto switch to the house banks for brief seconds it needs to start the engine. The combining mode is for manual handling (which in most cases you will never use). Of course this only occurs if you have the ACR inline with the combining switch.
I have yet had the need to ever to do the combine function other than in testing and troubleshooting of various electrical gremlins as I re-wire the boat.
I don't know anything about the echo charger system, but for what it is worth the Blue Seas solution works incredibly well. Unlike when I had my Catalina with just a perko 1/2/both/off switch - I have yet to actually use the switch for starting etc...and it has been one of the few upgrades i have done that takes the nuisances out of the sailing regimen I learned I had to deal with with my previous setup...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
