Originally Posted by JimsCAL
Why are saying the old bottom paint needs to be stripped? If it's smooth and adhering well, a fresh coat (or two) may be all that's needed. Two quarts should be enough for one coat on an ODay 25. Bottom paint has poisons in it (typically copper based) to limit growth. Since you are in Kansas and probably on a fresh water lake, use a paint formulated for that use.
I was told it needed bottom paint, and then provided this picture (among others). The assumption that it would need to be stripped was mine - all I know about painting is that you strip a house before painting it - I assumed the same was also true for boats.
Does it look like I should just be able to paint over this, then?
