SailNet Community - View Single Post - Right of way question
post #64 of Old 09-09-2008
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
Another part of the "avoid collision" rule is that you should do everything that you are capable of doing to avoid collision. The common maneuvers would be tacking/gybing/spilling sail, etc. But it also means that if your engine is easily started; reverse is part of your capability to help avoid a collision. So in the instance of two boats approaching on a collision course; starting the engine and running it in standby for an emergency maneuver should not be considered a sailboat "under power".
JMHO...
KeelHaulin is offline
