CD, I have had the same problem. Has it been the same slot on the receptacle end in both your failures? I have a feeling that all the failures are on the same slot and that this is a result of not completely turning the plug before tightening the holding ring and because of the configuration of the blades full contact is not made. If this is the case it is neither corrosion nor poor workmsship that are the cause of the failure.
