Originally Posted by k1vsk
If you routinely connect/disconnect with the power on, internal arching inevitably can occur causing the burn marks in your picture. As you can imagine, the instantaneous connection/disconnect, particularly if the conenctor pins are dirty, can arch. I don't know if you do this but I've seen many people do it and, correctly or not, I attributed their failed connectors to that process.
It's always a good habit to first shut down the breaker before disconnecting.
K1,
When you say "shut down the breaker", are you referring to the shore power breaker in the boat, or out on the dock? I always shut down the breaker in the boat, but have never shut down the breaker at the dock. In all honestly, it never occurred to me that I should do that...
