  #29 (permalink)
Old 09-11-2008
Sapperwhite's Avatar
Sapperwhite Sapperwhite is offline
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
Originally Posted by k1vsk View Post
It's always a good habit to first shut down the breaker before disconnecting.
Absolutly (dockside pedestal breaker). Aside from arcing when you plug a live cord into the boats receptical, there are personel safety issues here (as some others have noted). Anyone else ever concider they are holding a live line while standing near a whole lot of water? It is not the voltage that will kill you (well, not 120v), but the amperage. 30 amps, let alone 50 amps, is way more than enough to disrupt your hearts rhythm.
If you are holding the cord while wet or standing in water, and the electricity seeks ground through you, you can be injured or killed as it passes through your heart. Your skin does act like a faraday cage for your internals, but that can be overcome. Otherwise, everyone who ever got zapped with even low amps would go into cardiac arrest (which doesn't happen).
Long story short:
When coming in; breaker at the pedestal off and breaker onboard off, plug in on the boat, then plug in at pedestal, breaker on at the pedestal, then breaker on the boat on.
Dictated, but not read.
