SailNet Community - View Single Post - Raytheon ST-60 instruments
post #2 of Old 04-20-2001
Jeff_H
Moderator
Jeff_H's Avatar
Check its installation. Is it installed near the centerline and foreward of the keel? If it is on the side of the keel it will be affected by heel angle and turbulance eratically. Also how do you know it is reading eratically and not reflecting you actual speed through the water? Also check you averaging function which if it is set to average not frequently enough can give very bizarre readings.
Good luck
Jeff_H is offline
