SailNet Community - View Single Post - Rudder anode question
post #1 of Old 01-02-2004 Thread Starter
aflanigan
I plan on installing a couple of zinc anodes on my rudder head plates to prevent further corrosion of the lower ends. My question is whether these anodes need to contact the water to be effective. It is only the lower inch or so of the rudder head which normally contacts the water; I''m assuming I need to have the anode in this area, and that a disc anode mounted on the pivot bolt of the rudder (which is up above the water surface) will offer ineffective protection. I guess a tear-drop shaped anode would work best along the lower edge of the rudder head plates.
Allen Flanigan
Alexandria, VA
aflanigan is offline
