SailNet Community - View Single Post - Hull Delamination
post #7 of Old 09-15-2008
sailingdog
Be aware that just injecting epoxy is going to have some serious side effects that may cause problems, as the hull where the epoxy is injected will be much heavier and probably less stiff than the areas that have a proper foam core.
If the inner skin isn't punctured, you can probably do a fairly good job of re-coring the hull yourself, especially if you have a sister ship to use to make a mold of the damaged area. There was a good article on doing this in a recent magazine from this past summer. If I can find my copy of it, I'll let you know what magazine it was.
Originally Posted by fastforward26 View Post
Thanks for the responses. Yes, I know there is delamination. I am looking for someone who may have experience with repair of foam core construction and if there is a product which can be injected to stiffen the affected area. I'm trying to avoid scrapping the boat. Removal of the skin and repair will excede the value of the hull. A surveyor can confirm damage but would not advise on repair techniques.
sailingdog is offline
