Well I guess I'm too late with this since the job is done, but for anyone else...
I purchased the WM hose lube. I figured I was paying way too much for soap but I would give it a try. It turn out to be much more like KY water based lube than soap. It worked really well. I would recommend WM lube (or KY) and a heat gun. That combo did the trick for me using the white hose, even on barbed fittings. Use enough heat on the hose to get it nice and soft, but not burned. Put the lube on the male fitting.
