SailNet Community - View Single Post - NMEA 0183 how to connect my new plotter
post #5 of Old 09-18-2008
tommays
tommays's Avatar
In 0183 the GPS transmit wire allways connects to the receive wire of the decive and a common wire (Single ground)
Anything giving info to the GPS would have to have its transmit wire connected to the GPS recieve wire and the common wire (single ground)
The 0183 is really just RS-232 (old mouse) given a marine name
Even in a limited manual they should tell you the color code of the wires
Then as mentioned you get into the proprietary data BUT if it is a 0183 device then it should work but there is really no way to check other than it works
i gotta read the date
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
