Vitesse...what size charger do you have? the Honda won't do it alone.
With 700ah's you will need to replace 350ah's at 50% depleted. If they are flooded 6V rather than AGM...you can put 100-140amps in during bulk charging. That is pushing the Honda's output limit and there will also be conversion losses...suggest you get something in the 100amp range as running the Honda for 3 hours will bring them most of the way back up.
