IMHO, it isn't worth spending the money on the vent filter
line, since it really is going to only make the problem worse. The problem is that you probably don't have sufficient ventilation for your
holding tank, and adding a filter is going to make that worse, not better. The odor-causing bacteria are anaerobic, and if you increase the ventilation to the tank, it won't stink, since the good aerobic non-sulfide producing bacteria will multiply and the sulfide producing anaerobic bacteria will die off.
Another problem with stinking
holding tanks is when you flush using seawater, since the seawater often contains small lifeforms that will die and decompose, adding to the smell...but that usually is more a problem in the hoses than the
holding tank itself.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
