head problem
My 30'' Morgan has an added water tank and as a result I had to install the holding tank to one side and the inlet is about 6" higher than the outlet from the head and on the starboard side. The head is on the left. I was going to run the hose from the head, up the bulkhead about 18". Then back down to the tank inlet. Will there be waste in the hose, and will it run back into the head. Is there a way to solve this.
