SailNet Community - View Single Post - Hunter 29.5 vs. Beneteau 281?
post #7 of Old 09-21-2008
johnshasteen
johnshasteen's Avatar
You didn't say where you plan on doing most of your sailing. If it's bays and close-to-shore, coastal crusing then any boat you like will do. If you are thinking about offshore in a year or two when you are more accomplished, neither of these boats is a blue water warrior - keep looking. As others have said, for the same money you can buy an older, much stronger, well maintained boat from the 70's in the same size range - if it needs work, the price will be lower.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
johnshasteen is offline
