Old 04-22-2001
kimberlite kimberlite is offline
kimberlite is on a distinguished road
Need a little help in the plumbing department!!
check valve in the main bilge pump line is not recommended. if it jams or plugs up you are out of luck in an emergency. i installed a small automatic 500 gph pump and a separate bilge hose and a check valve from west. this keeps the bilge dry.
eric
